MogLite Posted January 18, 2006 Share Posted January 18, 2006 With a twin battery setup any reason why the earth connection cannot be connected as Chassis -> Battery one -> Battery two -> Chassis Battery one is not normally connected to battery two, but I cannot see it doing any harm Why do this ? So I can disconnect the +ve connections in a few seconds, connect them in series to get a 24V temporary connection for an on-board welder I'll be running a split charge if that makes any difference Simonr - if you are reading this. PM me a price for your relay - just the relay, I'll be doing my own cabling Throw in a couple of X-eng stickers if you've got em yet. Quote Link to comment Share on other sites More sharing options...
dollythelw Posted January 18, 2006 Share Posted January 18, 2006 Nope, no problem. Wire the 24v with 400A andersons and you're in business Are you sure its for the welder or is it just for your hairdryer and vanity mirror? Quote Link to comment Share on other sites More sharing options...
MogLite Posted January 18, 2006 Author Share Posted January 18, 2006 Nope, no problem. Wire the 24v with 400A andersons and you're in businessAre you sure its for the welder or is it just for your hairdryer and vanity mirror? I put on the door mirrors yesterday, so they will have to double up as a vanity mirror So it must be for the hair dryer then, oh the joys of having hair Quote Link to comment Share on other sites More sharing options...
02GF74 Posted January 18, 2006 Share Posted January 18, 2006 With a twin battery setup any reason why the earth connection cannot be connected asChassis -> Battery one -> Battery two -> Chassis Battery one is not normally connected to battery two, but I cannot see it doing any harm Why do this ? So I can disconnect the +ve connections in a few seconds, connect them in series to get a 24V temporary connection for an on-board welder I don't understand ^^^^ your connection description. If the -ve of both batteries goes to chasis (earth) you would need to undo that when connecting them in series to get 24 V. Quote Link to comment Share on other sites More sharing options...
