Mo Murphy Posted September 27, 2008 Share Posted September 27, 2008 Evening all, My earlier servo is kaput (vacuum pump is still producing vacuum) so I'm going to change it for the later type, which uses a 3 ports master cylinder instead the current one which has 2 as I have a couple kicking around. Now which brake pipe goes where ? I assume there are 2 ports for the front brakes and one for the rear. Will it be ok to disconnect the front brake pipes from the 't' piece on the footwell where they are split and fit a new bit of pipe to each from the master cylinder ? Cheers in advance Mo Quote Link to comment Share on other sites More sharing options...
patch1 Posted September 27, 2008 Share Posted September 27, 2008 when you say new type you mean say 300Tdi and old type as in 2.5D. Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted September 27, 2008 Author Share Posted September 27, 2008 Indeed I do Patch Quote Link to comment Share on other sites More sharing options...
patch1 Posted September 27, 2008 Share Posted September 27, 2008 I would stick with the old type myself. I have an Nreg 90 and I have changed mine and my dads on his Rreg 90 several times as they constantly crack due to flexing around the rim next to the fixing bolts for that nast pressed steel master cylinder thay now use. Thats why alot of landrovers I think 300Tdi onwards have carp and heavy breaks. Rant over. Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted September 27, 2008 Author Share Posted September 27, 2008 I have 2 good ones, Patch and want to save myself the expense of buying new parts. Mo Quote Link to comment Share on other sites More sharing options...
patch1 Posted September 27, 2008 Share Posted September 27, 2008 I can agree with that. Mark Quote Link to comment Share on other sites More sharing options...
steve_d Posted September 27, 2008 Share Posted September 27, 2008 If this master cylinder is the same system as the RRC then the third port is the secondary braking system. The RRC front calliper has primary and secondary feeds to it and they enter at different points. If you used this master and piped it using all three ports then the fronts would be fed off different systems which would be very dangerous if one failed. I don't think you should use it. Steve Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted September 27, 2008 Author Share Posted September 27, 2008 They're different to the RR Steve as Defender calipers only have a single feed into them. Mo Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted September 28, 2008 Author Share Posted September 28, 2008 Anyone know anything about the above ? Someone must have done it ! Mo Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted September 29, 2008 Author Share Posted September 29, 2008 Just to clarify my question for all, I'll swap over the entire brake pedal/servo assy, which pipe goes to which port on the master cylinder ? Mo Quote Link to comment Share on other sites More sharing options...
