redisthebest Posted October 5, 2008 Share Posted October 5, 2008 Just got my first freelander 2 weeks ago and i love it - its a 99 V 1.8 xei 3dr. I thought i would give it my own little service and so ordered a kit offthe internet for air, oil, pollen filters and plugs. having spent 2 hours finding the sump and oil filter (and the undercarriage falling on my head the oil and filter are changes as is the air filter. so apart from the spark plugs which i keep staring at wondering how to change (looks complicated under the bonnet in tems of removing the fuel injection stuff) i cant find the pollen filter and wonder if i actually have one as i have air con ? anyone know ? as you ave probably guessed i am no mechanic but i like to have ago !! cheers Quote Link to comment Share on other sites More sharing options...
andyb Posted October 6, 2008 Share Posted October 6, 2008 For the spark plugs remove the black cover over the engine. IIRC it is held on with two small bolts/set screws and you will have to remove the oil filler cap as well to remove the cover. The pollen filter is behind the glovebox.....stand on your head in the passenger footwell. You will have one whether you have air con or not. HTH Quote Link to comment Share on other sites More sharing options...
Les Henson Posted October 6, 2008 Share Posted October 6, 2008 Spark plugs - remove rocker cover centre strip (2 x phillips screws) they should be captive. The strip will lift off and the plug caps can be seen. Careful how you pull them off - they can break quite easily. There's no need to keep the plug leads in order - they are the right length to reach their respective plugs. 14mm spark plug socket is needed and they are deep set, so an extension bar is needed. Les. Quote Link to comment Share on other sites More sharing options...
andyb Posted October 6, 2008 Share Posted October 6, 2008 OK so I miss remembered the oil filler cap bit Quote Link to comment Share on other sites More sharing options...
