Jamaican Defender Posted October 8, 2008 Share Posted October 8, 2008 Have a discovery 2 with air suspension fitted in the rear. It intermittently leaks down on the drivers (right) side. I have seen it mentioned that it may be an air bag leak, or a valve that sontrols air flow sticking. I have noticed the complaints on the forums are more common to the drivers side. Why is this? Any thoughts on what to check to determine whether its a problem with the air spring or a control problem. Thanks in advance Quote Link to comment Share on other sites More sharing options...
BogMonster Posted October 9, 2008 Share Posted October 9, 2008 Fat drivers? A household plant sprayer with dilute soapy water mix in is the best thing for locating an air leak, spray it on the spring and there will be bubbles everywhere if it is at fault. Quote Link to comment Share on other sites More sharing options...
