joe sharpe Posted October 15, 2008 Share Posted October 15, 2008 thanks for all the help with previous post (lost clutch) still needing a little help ,how high will i have to jack up my discovery (onto axle stands) to enable me to remove box without to much of a struggle as i am not a stick insect cheers joe Quote Link to comment Share on other sites More sharing options...
JimAttrill Posted October 15, 2008 Share Posted October 15, 2008 Well if you are prepared to do it, you don't have to jack it up at all, just use a trolley jack under the gearboxes. Quote Link to comment Share on other sites More sharing options...
andyb Posted October 15, 2008 Share Posted October 15, 2008 Jim is right if you just want to do a clutch. If you want to remove the gearbox then you will have to get about 20inchs under the chassis rails and you'll still have to remove the gear levers to get it out.......ask me how I know Quote Link to comment Share on other sites More sharing options...
Les Henson Posted October 15, 2008 Share Posted October 15, 2008 Discovery clutch change (gearbox back method) http://forums.lr4x4.com/index.php?showtopic=6719 Les. Quote Link to comment Share on other sites More sharing options...
joe sharpe Posted October 16, 2008 Author Share Posted October 16, 2008 Discovery clutch change (gearbox back method)http://forums.lr4x4.com/index.php?showtopic=6719 Les. thanks for the link do i have to remove the high/low stick? cheers joe Quote Link to comment Share on other sites More sharing options...
Les Henson Posted October 17, 2008 Share Posted October 17, 2008 No, the stick stubs stay in place. When you lower the gearbox down, they don't interfere with the distance that the gearbox will move back. Be very careful that the gearbox doesn't roll as you slide it back - it can jam in the transmission tunnel and is very awkward/difficult to free off. The jack under the handbrake drum is critical, so keep an eye on it. Les. Quote Link to comment Share on other sites More sharing options...
joe sharpe Posted October 19, 2008 Author Share Posted October 19, 2008 well thanks for all the advice i have decided to split transfer box from the gearbox done it this morning (well chuffed), the fork has some wear but the clutch plate springs have departed company from the plate,i have a full kit on its way to fit . can someone advise me what the seal is called on the transfer case as i need a new one and never ordered it with clutch . cheers joe Quote Link to comment Share on other sites More sharing options...
Les Henson Posted October 19, 2008 Share Posted October 19, 2008 Seal - transfer box input- FRC2365 Les. Quote Link to comment Share on other sites More sharing options...
