Lightning Posted October 17, 2008 Share Posted October 17, 2008 should the door locks on a 2006 Defender have a return spring on the key? That is, when you insert the key and turn it to open the door should the key spring back to the vertical position when you let go? The reason I ask is that both locks have been replaced and there is no spring action...the key just flops from side to side (although it does work) and I'm sure it was not like that before! Quote Link to comment Share on other sites More sharing options...
Andrew Chua Posted October 19, 2008 Share Posted October 19, 2008 should the door locks on a 2006 Defender have a return spring on the key? That is, when you insert the key and turn it to open the door should the key spring back to the vertical position when you let go?The reason I ask is that both locks have been replaced and there is no spring action...the key just flops from side to side (although it does work) and I'm sure it was not like that before! Is this vehicle a Td5? As far as i know they do not spring back. kinda dumb, but i seldom ever need to manually unlock it so it doesn't bug me. it's the same on the rear door. Quote Link to comment Share on other sites More sharing options...
