derekk111 Posted October 20, 2008 Share Posted October 20, 2008 hello it's that dreaded mot time again, and i'm after both inner wings. so far all i can find are range rover jobs you have to modify, any ideas? cheers. Quote Link to comment Share on other sites More sharing options...
Mark Posted October 20, 2008 Share Posted October 20, 2008 Bar the lightbox on the front, classic rangie and dicso1 inner wings are one and the same... what do you need to modify? Quote Link to comment Share on other sites More sharing options...
Orgasmic Farmer Posted October 20, 2008 Share Posted October 20, 2008 TRY HERE Quote Link to comment Share on other sites More sharing options...
disco_al Posted October 21, 2008 Share Posted October 21, 2008 inner wings are not classed as structural for the mot, and as there are no load bearing components within the 30cm limit should not really fail the test (depends obviously on where the corrosion is) Quote Link to comment Share on other sites More sharing options...
sotal Posted October 21, 2008 Share Posted October 21, 2008 Mine failed the MOT, if it's got ABS then that sits on the inner wing, mine failed on being within 30 cms of the ABS modulator. I have heard of them being failed for being within 30cms of the suspension turrets, even though they're not connected. Quote Link to comment Share on other sites More sharing options...
