SteveRK Posted October 31, 2008 Share Posted October 31, 2008 With MOT time looming I knew the B pillars were a bit suspect where they joined the outer sills so time for a thorough investigation. The N/S B pillar was in remarkably good shape and lulled me into a false sense of hope but onto the O/S what initially looked like a 'local patch required' type repair turned out to be more substantial once the toffee hammer was put to work. Once I started getting to grips with the corrosion & not knowing the extent of damage I decided to play it safe & weld a small re-enforcing plate on the side of the pillar - I didn't want to get into a situation where the whole pillar might drop albeit I was pretty sure it wouldn't due to it also being spot welded to other parts of the door aperture: The Problem once I had cut back to sound metal: Initial repair used 2 plates suitable fabricated and fitted either side of the pillar. I went for metal around 1.7mm thick which made fabricating a lot more effort but a lot easier to weld as the sills are pretty thick steel. Lots of fettling required to get them formed close and tight. Vertical welding and upside down welding is definitely a difficult skill for me to master so I settled for making a series of short blobby, crappy looking welds. Took more time to dress up with the grinder afterwards than the welding itself took - always a good measure as to how good your welding is I guess. Then the middle piece. This I made in thinner 1.2mm steel as it needed to fit nice and snug. Even more fettling required as I particularly wanted this to be a close fit to keep that MOT failer off the scent: Anyways it should last a good few years and will be largely hidden by the plastic sill trim. Good experience for me in upside down welding but a long way to go yet before I can lay a continuous bead down Quote Link to comment Share on other sites More sharing options...
ThreeSheds Posted November 1, 2008 Share Posted November 1, 2008 That's a neat repair! My B pillars were solidly attached to the floor but not much else, so when I replaced the sill with box-section I did have to position it and then jack it up a couple of mm to lift the middle, but I am not entirely sure if this was the pillar dropping or LR tolerances. In any case, the 'metal' (ahem!) that I took out was definitely not supporting anything so I think that any 'dropping' that occurred would have already taken place on the local speed-bumps. Good experience for me in upside down welding but a long way to go yet before I can lay a continuous bead down [caveat] Below is MY thinking using gas-less MIG. Although I first used MIG years (decades) ago, that was on nice gauge metal on a bench and I have never been taught to weld. Any of the techniques described below may be wrong, but they seem to work for me. [/caveat] I don't even try to lay down a continuous bead on thin metal - I am most certainly not a skilled welder and I find that after a run of maybe an inch it will blow through even on the lowest settings. And on low settings I am not happy with the penetration. On thicker metal (say 2mm plus ) I can do a continuous bead, but I find that the distortion is too high (an early attempt at making a bumper from 4"x2" 3.5mm wall resulted in it being bent like a banana!) so I usually weld in a series of 1" runs, each one mid way between two previous ones. So what I do for thin metal, (reaching for tin-hat) is to repeatedly do short runs (duration depending on metal thickness) starting the next run as soon as the weld/slag pool from the last run starts to solidify. At the end of one short run, I do not remove the wire from the pool, but I make sure that I start the next run before it completely solidifies. If I am welding a non-stressed area and the metal is 'a bit thin' then this method may take the form of a series of overlapping spot-welds - each one of less than 1 second duration. On normal thickness (16 gauge?) I find that I can comfortably do about a 10mm run at a time. For vertical welding I usually go upwards - going downwards with gas-less means that you run into the ever-growing pool of slag and it is difficult to see. Upside down welding with gas-less is nasty. The amount of spatter and slag is huge and will easily set fire to overalls (ask me how I know!). In this situation I make a pent roof over myself with sheets of plywood so that the spatter rolls away, and I put in ear-plugs since having a ball of near molten metal bouncing around in your ear is not nice (ask me how I know that too!). Right - let the flames begin! Roger. Quote Link to comment Share on other sites More sharing options...
steve_d Posted November 1, 2008 Share Posted November 1, 2008 Right - let the flames begin!Roger. A subtle hint, perhaps, that you also managed to set fire to the car. Steve Quote Link to comment Share on other sites More sharing options...
ThreeSheds Posted November 1, 2008 Share Posted November 1, 2008 A subtle hint, perhaps, that you also managed to set fire to the car.Steve Done that before*, but not to this one - yet No - what I was meaning was that I was expecting people with genuine welding knowledge to be critical of my ideas... Rog *Tell you what - on the occasion that I did set fire to a car while I was under it - and I mean REALLY set fire to a car - it's amazing how much of a headless-chicken I became... I did put it out though and (apart from the smell) there was no irreparable damage. It would be nice if I could have someone fire-watching when I weld, but I just don't have that option I am afraid. Quote Link to comment Share on other sites More sharing options...
SteveRK Posted November 1, 2008 Author Share Posted November 1, 2008 I will try that technique of keeping the tip in position after pausing as i usually remove the nozzle completely from the area and then start again - with the result that I get dis-jointed fillets (sounds like a medical condition!) I know what you mean about thin metal, even on mine with the lowest setting it just about copes with 1.2mm but more often than not will burn a hole. I have a AC/AC voltage transformer that I have tried to lower the voltage into the mig which helps reduce the current but makes the wire feed a bit notchy. Quote Link to comment Share on other sites More sharing options...
SteveRK Posted November 1, 2008 Author Share Posted November 1, 2008 Ta for the compliment three-sheds - amazing what a bit of paint does to flatter the repair - it looked ragged before painting. Quote Link to comment Share on other sites More sharing options...
