300tdi brakes poor
keithjh
Hi All,
while servicing the truck, it was noticed that the discs were getting past their best, so changed all 4 discs new pads etc, also chganged a couple of brale lines that were badly corroded.
The brakes work but are not as good a they were when i used to use it (wife now uses it for work etc). Anyway not losing fluid anywhere, no air in system, stops in a straight line, no pumping, servo appears to be working fine, what have i missed? only thing i can think of is the vacuum unit attached to the engine block
Regards
Keith
Would second that - have been surprised at how long everything can take to bed in at times .
Have often seen the figure of 100 mls mentioned - but of course the number of times the brakes are applied comes into it as well .
Hard braking in the early stages is also to be avoided.
