Reng Posted November 5, 2008 Share Posted November 5, 2008 I have developed a lack of power on my Disco TD5 it has 120 000KM on the clock. The lack of power is most noticeable on pull of as it takes a few seconds longer than normal to get the vehicle moving. As it is an Auto box and I tow a trailer you can floor it when stationary and not move. I have also noticed a higher pitched whistle / whine from the turbo all of the time when it is on boost but more so at higher revs during Auto box kick down. Where should I start looking? Quote Link to comment Share on other sites More sharing options...
Les Henson Posted November 5, 2008 Share Posted November 5, 2008 You may have a leak in one of the intercooler pipes/intercooler itself. Any leak will prevent the turbo from working. There's air pressure in the pipes - even when the engine is ticking over, so feel along them for any leaks. Les. Quote Link to comment Share on other sites More sharing options...
JimAttrill Posted November 5, 2008 Share Posted November 5, 2008 The high-pitched whistle could be a blown exhaust gasket which will lower the exhaust pressure at the turbo if it is bad enough. Take off the plastic thingy and have a look for carbon deposits especially at the front and the rear of the manifold. If it has blown, the chances are that the manifold will have to be skimmed flat as it will just blow the gasket again. Quote Link to comment Share on other sites More sharing options...
Reng Posted November 6, 2008 Author Share Posted November 6, 2008 Thanks for the replies I will check the areas indicated Quote Link to comment Share on other sites More sharing options...
