kevinr Posted November 24, 2008 Share Posted November 24, 2008 I've been reading this in the hope that it could solve my slight misfire problem, however, I'm not entirely sure if the dizzy I have is the correct one. Any of you guys know if the one fitted to a 97 Disco V8 ES is the correct type? From what I can gather it is, but before I spend the money I'd just like to double check. Thanks Quote Link to comment Share on other sites More sharing options...
teabag Posted November 24, 2008 Share Posted November 24, 2008 What u should have for a 1997 D1 is ERR5209 distributor and RTC5089 2pin module (which is no longer available) or STC1184 3 pin module Quote Link to comment Share on other sites More sharing options...
kevinr Posted November 24, 2008 Author Share Posted November 24, 2008 What u should have for a 1997 D1 is ERR5209 distributor and RTC5089 2pin module (which is no longer available) or STC1184 3 pin module Thanks for the info I did try Landrover, but aside from being very sketchy about giving out part numbers..he did kindly try to sell me an upgraded module at about £90 plus and additional £30 for a harness to fit it!! The dizzy is compatible, just need to sorce that ignition module now...which is proving hard. Quote Link to comment Share on other sites More sharing options...
