LRDISCOVERY Posted November 29, 2008 Share Posted November 29, 2008 hi well I've spotted these " LAND ROVER 8JX16 ALLOY WHEELS DISCOVERY RANGE ROVER 8" Item number: 220320875886 " on ebay there local to me but would they go straight on a discovery or would I need spacers as they are wider than the standard 7j that are currently fitted .have sent ??? but no reply as yet. Quote Link to comment Share on other sites More sharing options...
Jake Lloyd Posted November 29, 2008 Share Posted November 29, 2008 Genuine 8Jx16x57- NTC6980. Will only fit Discovery series2 & Range Rover 4.0/4.6 B) Quote Link to comment Share on other sites More sharing options...
LRDISCOVERY Posted November 29, 2008 Author Share Posted November 29, 2008 Genuine 8Jx16x57- NTC6980. Will only fit Discovery series2 & Range Rover 4.0/4.6 B) Cheers thanks for quick reply so will they go straight on without the need for spacers? Quote Link to comment Share on other sites More sharing options...
custom-conversions Posted November 29, 2008 Share Posted November 29, 2008 Cheers thanks for quick reply so will they go straight on without the need for spacers? If you have a Series 2 Disco (99-05 ish TD5 Shape) they will. If you don't you need adapters as the wheel stud pattern is different. Quote Link to comment Share on other sites More sharing options...
LRDISCOVERY Posted November 29, 2008 Author Share Posted November 29, 2008 If you have a Series 2 Disco (99-05 ish TD5 Shape) they will. If you don't you need adapters as the wheel stud pattern is different. Cheers thanks Quote Link to comment Share on other sites More sharing options...
BogMonster Posted November 30, 2008 Share Posted November 30, 2008 That size rim was fitted to the ES spec Series 2 Discoverys fitted with the 255/65R16 tyre option. Quote Link to comment Share on other sites More sharing options...
