stuntman Posted December 11, 2008 Share Posted December 11, 2008 Hello one and all, Well I'm ironing out the flat spots in my 300 tdi disco engined and gearbox and transfer boxed defender. I have a couple of flat spots between the gears and I'd like to fit a full width intercooler then get the truck rolling roaded to tweek the fuel pump and the turbo properly. However can anyone recomend anywhere to get a good intercooler and fitting kit from? Also, I know it's been covered many times but can you give me your experiences of the difference it's made in performance and fuel economy. Thanks Andi Quote Link to comment Share on other sites More sharing options...
Guest diesel_jim Posted December 11, 2008 Share Posted December 11, 2008 I can vouch for allisport stuff, very good quality. However.... you say you've got flat spots.... is this just general "underpower" (maybe because you're running big tyres/heavy rollcage/carrying lots of stuff) or an actual "stuttering" of the engine (i.e. a mechanical fault?)?? If it's the latter, then fitting the big intercooler and tweeking the boost/fuelling isn't really curing the problem, i'd look more closely at the engine itself and what's causing the flat spots.... Tdi's normally pull pretty well and seamlessly through the rev range. Could be the lift pump not giving enough fuel (cheap and easy to change) or the FIP itself might have a fault. Have you fitted a new filter? kinked pipe anywhere? simple things like this are cheap and easy to check. Quote Link to comment Share on other sites More sharing options...
stuntman Posted December 11, 2008 Author Share Posted December 11, 2008 No it's just I've driven a few standard 300 tdi's with 265/75/16's on and they all seem to have a flat spot between 2-3 not major just noticible. Everything on the engine and the fuel system is new (at least once- rubbish britpart items have been replaced a couple of times) etc. Quote Link to comment Share on other sites More sharing options...
mike4444244 Posted December 11, 2008 Share Posted December 11, 2008 Tape measure and scrapyard, IIRC i got one off a xantia or an XM? it was full width and cost £10... Mike Quote Link to comment Share on other sites More sharing options...
BigSi110 Posted December 11, 2008 Share Posted December 11, 2008 Brunel intercooler in my 300Tdi 110 and I very highly recommend them! For me, no improvement in fuel economy, but I do use the extra power. I can't be certain of the EXACT power improvements as I haven't rolling-roaded my 110 yet, but you should notice a something akin to releasing a binding brake. Quote Link to comment Share on other sites More sharing options...
stuntman Posted December 11, 2008 Author Share Posted December 11, 2008 Brilliant, thanks chaps. I may be down a scrappie near you very soon Quote Link to comment Share on other sites More sharing options...
JST Posted December 11, 2008 Share Posted December 11, 2008 i've got a td5 going for not alot you could plump that inline with the existing one, or fit two tdi ones in series - someone on difflock did this with good results. Quote Link to comment Share on other sites More sharing options...
Badger90 Posted December 15, 2008 Share Posted December 15, 2008 IRB developments, a mate got his TD5 intercooler and chip done of him and he a bloody good chap http://www.irbdevelopments.com/ Quote Link to comment Share on other sites More sharing options...
