burn_e Posted December 26, 2008 Share Posted December 26, 2008 Can the water pump in a Disco 1 loose its pumping capabilities partially? Or is it just hopp or topp with these ones. Means it works great or not. Why do I ask? Have the impression that the pumping performance is a bit down. I observed, that the little torrent/fontaine in the overflow canister has weakend. Well could this also explain the slight higher temperatur reading at the gauge?? Quote Link to comment Share on other sites More sharing options...
Les Henson Posted December 27, 2008 Share Posted December 27, 2008 If anti-freeze hasn't been used all the time, then the pump vanes can corrode and this will reduce the efficiency of it. Your thermostat may not be fully opening, which will restrict flow, so I would change that first (or remove it to see if there's any difference). Les. Quote Link to comment Share on other sites More sharing options...
burn_e Posted December 27, 2008 Author Share Posted December 27, 2008 thermostat is checked and working. Removed today the serpentine belt and turned the waterpump pulley by hand...spinned easy - with no remarkable observations. is the only way to check the condition of the pump to pull it out? Quote Link to comment Share on other sites More sharing options...
Les Henson Posted December 27, 2008 Share Posted December 27, 2008 Afraid so - you can't see the impellor with it fitted. Les. Quote Link to comment Share on other sites More sharing options...
pinny Posted December 27, 2008 Share Posted December 27, 2008 thermostat is checked and working.Removed today the serpentine belt and turned the waterpump pulley by hand...spinned easy - with no remarkable observations. is the only way to check the condition of the pump to pull it out? if your going toreplace the pump i would also do the p gasket as thay are prone to leak when you distorb the pump as 2 of the bolts go into the block mine leaked anyway after i had put it back toghether.chris Quote Link to comment Share on other sites More sharing options...
