Icedmunkie Posted December 30, 2008 Share Posted December 30, 2008 Whilst driving along in landlords 110 there is a knocking noise. Checked the props and the cv joints, its def the front axle. Been told that the difflock might be stuck in?? The difflock light does not work due to the previous owner fiddling around with the electrics. Anybody got any other suggestions?? Quote Link to comment Share on other sites More sharing options...
mmgemini Posted December 30, 2008 Share Posted December 30, 2008 I suggest you get the difflock light working pronto, otherwise it could cost you a lot onf money like it did a friend of mine. In his case a new front axle...... Also take the front prop off. Yes right off, then check both of the u/j's are not seized. mike Quote Link to comment Share on other sites More sharing options...
Icedmunkie Posted December 30, 2008 Author Share Posted December 30, 2008 I suggest you get the difflock light working pronto, otherwise it could cost you a lot onf money like it did a friend of mine. In his case a new front axle......Also take the front prop off. Yes right off, then check both of the u/j's are not seized. mike Cheers Mike, As per usual your a fountain of advice! How are you btw? Its been a while since I spoke to you or Margaret!! Chris Quote Link to comment Share on other sites More sharing options...
