straightshooter Posted January 7, 2009 Share Posted January 7, 2009 Hi guys just a quicky can anyone tell me how to fix my reversing lights checked the bulbs and they are ok Quote Link to comment Share on other sites More sharing options...
WESTENDER Posted January 7, 2009 Share Posted January 7, 2009 check the fuse, if thats ok then check the switch in the gearbox, there care two possible positions depending on which gear box you have Quote Link to comment Share on other sites More sharing options...
straightshooter Posted January 7, 2009 Author Share Posted January 7, 2009 check the fuse, if thats ok then check the switch in the gearbox, there care two possible positions depending on which gear box you have where is the switch in the gear box my freelander is a 2004 freelander 1.8L 3 door Quote Link to comment Share on other sites More sharing options...
Rich Hyde Posted March 24, 2009 Share Posted March 24, 2009 where is the switch in the gear box my freelander is a 2004 freelander 1.8L 3 door Hi, did you get an answer to where this switch is? I have the same problem with my Freelander. Thanks. Quote Link to comment Share on other sites More sharing options...
western Posted March 27, 2009 Share Posted March 27, 2009 far as I can tell, the reverse light switch is on the lower front face of the gearbox casing Quote Link to comment Share on other sites More sharing options...
NVNL Posted December 12, 2015 Share Posted December 12, 2015 Many thanks, now I know where to start looking. Quote Link to comment Share on other sites More sharing options...
