jagwit Posted January 14, 2009 Share Posted January 14, 2009 1) Could anyone tell me what the part no is of a TD5 Turbo CHRA (central housing rotating assembly)? The CHRA is all the bits that rotate including the housing in which the rotating bits run - the part that one can see between the two outer turbo casings. 2) Any idea where one could buy this? I am told that the shaft on my turbo has "broken". Does that mean it is now in two parts? Any idea what causes this to happen? Quote Link to comment Share on other sites More sharing options...
BogMonster Posted January 14, 2009 Share Posted January 14, 2009 I expect you will find the part is either not available separately or the cost is prohibitive. Your best bet is probably to get a complete recon turbo I would say. Google shows up lots of possibilities for this http://www.google.co.uk/search?hl=en&q...earch&meta= which may or may not be much use to you due to your location. Quote Link to comment Share on other sites More sharing options...
jagwit Posted January 14, 2009 Author Share Posted January 14, 2009 I expect you will find the part is either not available separately or the cost is prohibitive. It HAS to be available from somewhere as my local turbo repair man will be doing exactly that for about USD450. He must surely get it from somewhere and then add his markup Quote Link to comment Share on other sites More sharing options...
BogMonster Posted January 14, 2009 Share Posted January 14, 2009 Any particular reason you aren't getting him to do the job? That doesn't seem like an unreasonable price to me. Quote Link to comment Share on other sites More sharing options...
jagwit Posted January 15, 2009 Author Share Posted January 15, 2009 Any particular reason you aren't getting him to do the job? That doesn't seem like an unreasonable price to me. He is doing the job, I just want to know for the sake of knowing. Quote Link to comment Share on other sites More sharing options...
