90/outbak Posted January 19, 2009 Share Posted January 19, 2009 Can someone please tell me what type of remote servo to fit to my Defender and also where in the system it is fitted? Thanks Quote Link to comment Share on other sites More sharing options...
western Posted January 19, 2009 Share Posted January 19, 2009 there isn't a clutch servo fitted on any Defender unless a previous owner has fitted one. if the pedal is too heavy to operate, try lubricating the shaft ends at the assembly under the bonnet or fit a late 300Tdi/Td5 clutch pedal assembly with the different return/assist spring. Quote Link to comment Share on other sites More sharing options...
Yostumpy Posted January 19, 2009 Share Posted January 19, 2009 there isn't a clutch servo fitted on any Defender unless a previous owner has fitted one. if the pedal is too heavy to operate, try lubricating the shaft ends at the assembly under the bonnet or fit a late 300Tdi/Td5 clutch pedal assembly with the different return/assist spring. Back in the late 90's Buyras Bridge land rovers down in devon/cornwall advertised a clutch lightening kit/device, supposed to reduce pedal effort by 70%, could contact them, they were still there 2 years ago. this ad was from oct '98 Quote Link to comment Share on other sites More sharing options...
