rusty_wingnut Posted January 21, 2009 Share Posted January 21, 2009 My front diff seems to have a lot of play on the pinion shaft. Is this a case of replace the bearing or is something I can adjust out? Quote Link to comment Share on other sites More sharing options...
Ex Member Posted January 21, 2009 Share Posted January 21, 2009 Most likely a bearing is gone. Check first that the pinion nut is not loose. If it is tight, you have a bad bearing. Quote Link to comment Share on other sites More sharing options...
Les Henson Posted January 21, 2009 Share Posted January 21, 2009 The pinion is pre-loaded. If the nut is loose then you might get away with re-pre-loading it, but once the bearing has been like that for a while - it's time to rebuild or replace the diff. 4 bearings in the diff - all taper roller and not that expensive to buy, plus the cover gasket.and shims. Setting the pre-load to factory spec is time consuming (unless you get lucky), doing it by feel is quicker and usually just as effective. Les. Quote Link to comment Share on other sites More sharing options...
