Duff fuel pump - 92 vogue
mabbs
Having an intermittent starting problem - R.R starts if left for a few days, runs fine, but then refuses to start.
has a good spark, so have investigated the fuel pump by testing what I believe is the feed wire (black, with a thin white line) with my multimeter. the feed is located at the top of the fuel pump, accessed via the boot floor.
When the vehicle has just the ignition on 4 volts only, on cranking this leaps to 13/14v. Furthermore I can hear nothing from the fuel pump. Before departing with a thick wedge, do you think I can be sure it is a failed fuel pump from this???......
Anyone repaired a fuel pump before?
Thanks
