lenny the lanny Posted January 24, 2009 Share Posted January 24, 2009 hi all please help disc alarm faulty the battery is going flat and the o/s indocater light stays on can I diconnect the alarm and were is it as Ihave a new battery to go on Quote Link to comment Share on other sites More sharing options...
teabag Posted January 24, 2009 Share Posted January 24, 2009 What model of disco??? and do you mean the fob battery. Quote Link to comment Share on other sites More sharing options...
lenny the lanny Posted January 24, 2009 Author Share Posted January 24, 2009 hi the main battery 1996 disco the green box under the glove box is flashing away Quote Link to comment Share on other sites More sharing options...
DaveJ Posted January 24, 2009 Share Posted January 24, 2009 hi the main battery 1996 disco the green box under the glove box is flashing away This is a bit of a non technical approach to the problem and worked for me when my alarm went nuts and then imobilised the car in the middle of know where Ok, so . Firstly I disconnected the battery and left it disconnected for a few hours. When I came back to the car I got a friend to sit in the drivers seat holding the ignition key in the start position I then proceded to connect the battery as they were sitting there. + connected first and as soon as I touched touched the negative the engine attempted to start as I jumped up like a s**ting dog . Anyway..just connected the battery as usual then and it all worked again fine - not done it since in couple of years. HTH DaveJ Quote Link to comment Share on other sites More sharing options...
drkwack Posted January 24, 2009 Share Posted January 24, 2009 Before you start blaming the alarm for draining the battery make sure its not the alternator thats the culprit,easy way is fully charge battery disconect the alternator and see what happens, if it stays full alt is your prob if not then it may be the alarm, how long does it take to flatten the battery, have you had the battery checked,this cold weather kills alot of them, Quote Link to comment Share on other sites More sharing options...
lenny the lanny Posted January 25, 2009 Author Share Posted January 25, 2009 hI all thanks for the answers but the indcator lights stay on and dash indecator lights also stay on when I take the relay out thats why I think its the alarm Quote Link to comment Share on other sites More sharing options...
