maxtherotti Posted February 3, 2009 Share Posted February 3, 2009 hi all whats the age/milage intervalfor a 300 tdi cam belt change? its a 98 manual if that makes any difference rob Quote Link to comment Share on other sites More sharing options...
Les Henson Posted February 3, 2009 Share Posted February 3, 2009 Every 72,000 miles or 6-years, whichever occurs first. If you've been a bit mental with the engine, then half that. If you shop at Waitrose, then the belt will never need changing, but Co-Op, Tesco, Sainsburys, carparks are far more demanding Les. Quote Link to comment Share on other sites More sharing options...
maxtherotti Posted February 3, 2009 Author Share Posted February 3, 2009 well it was done 4 years and 35k miles ago so will probbe ok for a while then thanks rob Quote Link to comment Share on other sites More sharing options...
freeagent Posted February 3, 2009 Share Posted February 3, 2009 I agree with Les, if you've been rough on your engine, reduce the interval.. I had mine changed before Christmas, it had been in there for less than 3 years, and just under 50k, but was pretty knackered (had stretched so the timing was slightly out, and had started to perish, causing tiny cracks beteween the teeth) Also change the tensioner and idler pulleys, mine were new 3 years ago, and both bearings were knackered when they were replaced at Christmas... Quote Link to comment Share on other sites More sharing options...
maxtherotti Posted February 4, 2009 Author Share Posted February 4, 2009 looks like it will be getting the cambelt done sooner than i thought then still it needs a water pump anyway so have a one hit day on it rob Quote Link to comment Share on other sites More sharing options...
