sargejnr Posted February 9, 2009 Share Posted February 9, 2009 im looking to get a set of lift springs from a mate and i was wondering what else i would need to lift my 300tdi disco, all im looking to get at the mo is springs, please advise, thank you Quote Link to comment Share on other sites More sharing options...
mscowley Posted February 9, 2009 Share Posted February 9, 2009 hi mate you'll need shocks as well Quote Link to comment Share on other sites More sharing options...
clbarclay Posted February 9, 2009 Share Posted February 9, 2009 You don't need new dampers. Some lift kits come with standard length dampers. Word of warning, some lift kits may deliver what they advertise, but not what you were expecting from the advertising. To get the most out of the suspension movement then either longer dampers or adjusting the damper mounts is required after a suspension lift, but then you have other issues such as the flexible brake pipes being too short and dampers bottoming out under compression which must be delt with. My first RRC was and now farthers RRC is lifted with just different springs and are ok for what the do, including pay and plays. Spring spacers are another option as is a body lift (spacers between chassis mounts and body). My personal view on lifitng vehicles is 'As much as neccisery and as little as possible'. Quote Link to comment Share on other sites More sharing options...
