rangy Posted February 11, 2009 Share Posted February 11, 2009 hey all. im wondering if anybody has replaced their rear o/s window with metal or any other means, i am looking to replace both of them to stop them getting popped outy when doing punch challenges. any help would be appreciated. Quote Link to comment Share on other sites More sharing options...
Orgasmic Farmer Posted February 11, 2009 Share Posted February 11, 2009 Heres a pic of a mates from a few years back. He simply traced round the glass onto a sheet of alloy and stuck it back in. Easy Quote Link to comment Share on other sites More sharing options...
Orange Posted February 11, 2009 Share Posted February 11, 2009 My Range Rover ended up with 2 sheets of perspex in the rearmost windows. Shatter-proof and still able to see through them - best of both worlds!! Remove the window glass and trace around the glass onto the perspex, then slowly cut them out with s atanley knife and a straight edge. If the perspex is thick enough you won't need to do anything other than refit them. If it's thinner, just run a bead of mastic around the window rubber to keep the worst of the water out... The mastic will also help hold a piece of string in the rubber, which, when pulled, makes the rubber flick out and the window sit in properly (if that makes sense...). Quote Link to comment Share on other sites More sharing options...
