Steve F Posted February 18, 2009 Share Posted February 18, 2009 I've got a Weber 34 ICH carb on my 4cyl 2286. Now i've had time to have a good look at it, I'm fairly sure a couple of bits are missing. There is no smaller lever next to the throttle lever (and therefore no link from this to the choke lever). When you pull the choke cable the only thing that moves is the choke butterfly valve (and this is loose and can flap about) I guess that could explain the why the engine isn't easy to keep going on tickover when its cold, unless the idle speed is kept a bit higher. Is this just bits missing, or is there a reason why someone would have done this? Quote Link to comment Share on other sites More sharing options...
Rich_P Posted February 18, 2009 Share Posted February 18, 2009 Is this just bits missing, or is there a reason why someone would have done this? Either they had another carb that they needed bits for, or (more likely from my experiences) removed it as the choke did bugger all to help with cold running. These single choke Webers aren't known for being a preferable type to use. It's often recommended to fit either the Solex or Zenith back on. Quote Link to comment Share on other sites More sharing options...
Steve F Posted February 19, 2009 Author Share Posted February 19, 2009 How easy is it to get hold of a good Solex / Zenith, or how easy to renovate an old one? New Weber from Paddocks would be £75 + VAT, which is tempting as its easy to get and new. Quote Link to comment Share on other sites More sharing options...
Steve F Posted February 20, 2009 Author Share Posted February 20, 2009 Anyone tried one of these ? http://cgi.ebay.co.uk/ws/eBayISAPI.dll?Vie...bayphotohosting Quote Link to comment Share on other sites More sharing options...
Rich_P Posted February 20, 2009 Share Posted February 20, 2009 Land Rover Orphanage is a good place. They do what they can to avoid selling rubbish. I would buy a Zenith from them without worry. Quote Link to comment Share on other sites More sharing options...
Steve F Posted February 20, 2009 Author Share Posted February 20, 2009 Just ordered a the Zenith copy from Land Rover Orphanage. Spoke to Richard there who was very helpful and highly recommends them. Will let you now how I get on. Quote Link to comment Share on other sites More sharing options...
Cartman Posted February 22, 2009 Share Posted February 22, 2009 I know Minivin bought one of these for a mates 2 1/4 and was very impressed to. http://cgi.ebay.co.uk/LAND-ROVER-SERIES-II...%3A1|240%3A1318 Looks like the LR Orph one but a bit cheaper? Paul Quote Link to comment Share on other sites More sharing options...
missingsid Posted February 25, 2009 Share Posted February 25, 2009 Either they had another carb that they needed bits for, or (more likely from my experiences) removed it as the choke did bugger all to help with cold running.These single choke Webers aren't known for being a preferable type to use. It's often recommended to fit either the Solex or Zenith back on. Strange I heard they were the thing everyone fitted?????? PS I have an unused and mostly boxed one (mouse nibbles) if required? Marc. Quote Link to comment Share on other sites More sharing options...
Rich_P Posted February 26, 2009 Share Posted February 26, 2009 People fitted them as an "economy" device, and when their tired original carb was being replaced they would be "amazed" by the improvement of performance. Said performance only came because they were replacing a fecked carb. The Twin Choke Weber is a different thing all together. Quote Link to comment Share on other sites More sharing options...
Steve F Posted February 27, 2009 Author Share Posted February 27, 2009 Just fitted the new Zenith copy. Took a bit of messing about to get it to run right, but turned out to be air leaking in through the PCV valve tube to the intake manifold - nothing to do with carb. Seems to be running really nice tonight, but will wait for for a few days and few cold starts for final verdict - but initial impression is very good. Quote Link to comment Share on other sites More sharing options...
