Lars L Posted April 16, 2009 Share Posted April 16, 2009 A mate with a 300Tdi manual Disco 1995 has come to the conclusion to change the front prop to one from a Disco II. Problem is that four different props are listed in Microcat. Does anyone know which one to use? And I suppose he needs to get another drive flange for the transfer box as well? Quote Link to comment Share on other sites More sharing options...
cipx2 Posted April 16, 2009 Share Posted April 16, 2009 He needs the one for the Td5 with manual transmission, part# TVB000100. Yes, the output flange needs to be changed as the propshaft has a different PCD on TB end. Quote Link to comment Share on other sites More sharing options...
Lars L Posted April 16, 2009 Author Share Posted April 16, 2009 Thanks! We have kinda figured that out by now, needed confirmation. Quote Link to comment Share on other sites More sharing options...
Boro Posted April 16, 2009 Share Posted April 16, 2009 What is the benefit of fitting a disco 2 prop then? if you dont mind me asking Quote Link to comment Share on other sites More sharing options...
Lars L Posted April 16, 2009 Author Share Posted April 16, 2009 It's said to be a cure for vibrations that often are side effect when fitting longer springs. We'll see... Quote Link to comment Share on other sites More sharing options...
muddog Posted April 16, 2009 Share Posted April 16, 2009 What is the benefit of fitting a disco 2 prop then? if you dont mind me asking ive done this and it just stop the vibrations!! Quote Link to comment Share on other sites More sharing options...
