uksniper1 Posted April 17, 2009 Share Posted April 17, 2009 hi guys,,just got a new set a 2 inch lift heavy duty springs for me rrc...and i noticed the rear srings are +50 and the fronts are +40..is this correct as i thought the front would be taller due to engine weight?...thanks for any help..cheers....wayne. Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted April 17, 2009 Share Posted April 17, 2009 I suspect the spring rates will be different to stock, so therefore measuring the actual height of an uncompressed spring (I assume) has little relevance to the final fitted height... Quote Link to comment Share on other sites More sharing options...
rangie_v8 Posted April 17, 2009 Share Posted April 17, 2009 Rear springs are firmer then front springs due to having to allow for a fully loaded vehicle plus a trailer, if they are fitted the wrong way round the front will be very stiff and the back will sit low and get worse with load. Quote Link to comment Share on other sites More sharing options...
uksniper1 Posted April 18, 2009 Author Share Posted April 18, 2009 ..thanks for the replies. Quote Link to comment Share on other sites More sharing options...
