Quagmire Posted February 17, 2011 Share Posted February 17, 2011 My VIP100 box is connected to an output on the Megajolt, which allows me to trigger an open loop condition whenever I like by changing the trigger conditions in MJ. Having set MJ to output an openloop condition at all times (for example you could say go open loop at any RPM >500, or for any MAP reading with a higher figure than 10kPA...) I still never get rich enough figures from my Bigas M84, maximum i see at WOT is about 13.8:1. I was also thinking of the OMLV R90, Toby- what AFR figures do you get on WOT? Quote Link to comment Share on other sites More sharing options...
TobyMellin Posted February 17, 2011 Share Posted February 17, 2011 Quagmire, just changing steering box on the truck at the moment, give me a couple of days and I'll get some readings for you. Had only just started tuning with the wideband when the box went. Quote Link to comment Share on other sites More sharing options...
Quagmire Posted February 17, 2011 Share Posted February 17, 2011 D'oh! Thanks, much appreciated Quote Link to comment Share on other sites More sharing options...
Quagmire Posted March 21, 2011 Share Posted March 21, 2011 Wow, I am rubbish- Sorry for the delay... finally got out there with laptop tonight and can confirm that my cranking advance was 6 degrees. I have changed it to 0, and will see if this helps at all tomorrow morning. Am seriously considering going full MS soon, with the idea of going LPG injection later. Fiddling about with my vap is doing my nut! It went for its MOT the other day and it was easier to put it through on petrol as at least the SU's would hold a tune for more than 5 minutes... Quote Link to comment Share on other sites More sharing options...
Quagmire Posted March 22, 2011 Share Posted March 22, 2011 Changing cranking advance to zero had no effect whatsoever on starting from cold this morning, will put it back to 6 degrees I guess. Quote Link to comment Share on other sites More sharing options...
