malco68 Posted May 8, 2009 Share Posted May 8, 2009 Greetings, I'm new here, found this place by accident yesterday whilst on a quest for new leaf springs for my 109FFR. I managed to break one and all four are pretty rusty, so it seems like a good idea to get replacements. I've searched high and low - any ideas?!! Quote Link to comment Share on other sites More sharing options...
101sean Posted May 8, 2009 Share Posted May 8, 2009 Hi and welcome. Fairly sure they are standard HD springs. Rear RH 272967 LH 272968 Front RH 276034 LH 265627 from my NATO catalogue. If you are not worried about true originality consider parabolic springs. You'll have to change the shocks as well but if your springs are that bad you should really do them as well anyway. Supposed to give a ride nearly comporably with coils If you are into the military side of things, check out http://forum.emlra.org/index.php Quote Link to comment Share on other sites More sharing options...
malco68 Posted May 10, 2009 Author Share Posted May 10, 2009 Hi and welcome.Fairly sure they are standard HD springs. Rear RH 272967 LH 272968 Front RH 276034 LH 265627 from my NATO catalogue. If you are not worried about true originality consider parabolic springs. You'll have to change the shocks as well but if your springs are that bad you should really do them as well anyway. Supposed to give a ride nearly comporably with coils If you are into the military side of things, check out http://forum.emlra.org/index.php Hi Sean, thanks for this. I have a set of brand new shocks, which I'll fit at the same time. I had been told that the springs weren't the same as standard HD springs, so this is encouraging news! Quote Link to comment Share on other sites More sharing options...
