StreetDragster Posted May 14, 2009 Share Posted May 14, 2009 Hi All, Doing a pinion seal on the Discovery 1, the guide says that the loating pin/cap should be re-installed with loctite 601 or 638, i'm struggling to get some locally, and mail order is too slow. Is there anything else i can use to do the same job? not really sure why the loctite is needed, the cover appears to be an interferance fit over the nut anyway. Thanks for any help Matt Quote Link to comment Share on other sites More sharing options...
StreetDragster Posted May 14, 2009 Author Share Posted May 14, 2009 how about loctites stud and bearing fit? "We have a wide selection of Loctite products available. Loctite Stud 'N' Bearing Fit is effective in facilitating the refitting of bearings into worn bearing housings. The compound securely seals between the bearing and its housing to eliminate fretting and corrosion. It also helps achieve the correct alignment of the bearing prior to setting. Features and Benefits Locks and seals studs into position Seals against leaks and vibrations Retains bearings into new and used housing" Local Halfords Carry That Thanks Matt Quote Link to comment Share on other sites More sharing options...
Jon White Posted May 14, 2009 Share Posted May 14, 2009 Thats the same thing. 601 is bearing fit! Jon Quote Link to comment Share on other sites More sharing options...
StreetDragster Posted May 14, 2009 Author Share Posted May 14, 2009 perfect, thanks! Matt Quote Link to comment Share on other sites More sharing options...
