RichardAllen Posted May 16, 2009 Share Posted May 16, 2009 I have a 2000W RING Inverter in my truck. The small on/off switch has a LED to show when it's switched on, but it is out of the way and I would like to wire it up to my dash which has several spare warning light slots. The inverter has a remote control accessory, which I could use, but I would rather just take a 12v lead out of the inverter and wire it up to a spare dash warning lamp. Does anyone know if this can easily be done ? Clearly I do not want to be accidentally wiring my truck up to a 240v output ! All help gratefully received Regards Richard Quote Link to comment Share on other sites More sharing options...
Turbocharger Posted May 16, 2009 Share Posted May 16, 2009 If you wire the inverter feed throughg a chunky relay (X-Charge?) then use an indicator light from the input. You could also have the inverter switched-live to keep yourself safe. Quote Link to comment Share on other sites More sharing options...
RichardAllen Posted May 19, 2009 Author Share Posted May 19, 2009 If you wire the inverter feed throughg a chunky relay (X-Charge?) then use an indicator light from the input. You could also have the inverter switched-live to keep yourself safe. Great idea, parts ordered. Thanks. Quote Link to comment Share on other sites More sharing options...
LandyManLuke Posted May 19, 2009 Share Posted May 19, 2009 The above just tells you you've supplied power to the inverter, not that it's on. What do you actually want to know? A 240v relay across the output of the inverter, switching a 12v signal circuit, would give you an indication of when the inverter is actually on. Quote Link to comment Share on other sites More sharing options...
