adam5809 Posted June 25, 2009 Share Posted June 25, 2009 Excuse the highjack, but can anyone suggest a cheap alternative to the rather pricey silicone hoses for plumbing in intercoolers? I have one sat in the garage just need to fit it Cheers Adam Quote Link to comment Share on other sites More sharing options...
Guest otchie1 Posted June 25, 2009 Share Posted June 25, 2009 Usual state of a 160,000 mile 2.5TD piston and the reason why they all smoke. Thermal stress. I found 3 out of 4 like that in mine all cracked in the same place. The 4th is probably the same I just couldn't see it. The extra crown pressure of an intercooler would have made it worse. Worse, how could it be worse Quote Link to comment Share on other sites More sharing options...
reb78 Posted June 26, 2009 Share Posted June 26, 2009 Surely just putting an intercooler in without a fuel pump adjustment will just enable cooler head temperatures and increase the life of the engine? The intercooler itself won;t increase the performance. So the intercooler alone is a good thing.. Quote Link to comment Share on other sites More sharing options...
Guest otchie1 Posted June 26, 2009 Share Posted June 26, 2009 Surely just putting an intercooler in without a fuel pump adjustment will just enable cooler head temperatures and increase the life of the engine? The intercooler itself won;t increase the performance. So the intercooler alone is a good thing.. No. An intercooler doesn't some how magically make fuel burn cooler. An intercooler cools the incoming air so you will get more air in the combustion chamber on every stroke - a denser charge. More air compressed into the same small space means an increase in both temperature and piston crown pressure irrespective of what you do to the fueling. Then when it ignites you have even more pressure on that poor old crown. Think submarines and depth charges. Laws of physics see? Ya kannae break 'em, Capt'n Intercooler = good thing on engines strong enough to take them. Land Rover never fitted one as standard to the 2.5TD for very good reasons. Instead they retooled their factory to make a brand new engine that could use an intercooler. Quote Link to comment Share on other sites More sharing options...
