defender dinky Posted June 19, 2009 Share Posted June 19, 2009 hi all,i have now a discovery 200tdi complete with a lift kit on , descent wheels,now i would like to know what could i use from it for my defender 90 1987 td upgrade, besides the engine 141000 miles, wheels and lift kit, loads of service receipts so it has been looked after in the passed, MOT failure, j reg 1992, and possibly talk to someone closer to home incase i get stuck abit later on. cheer's defender dinky, Quote Link to comment Share on other sites More sharing options...
Aragorn Posted June 19, 2009 Share Posted June 19, 2009 Your wanting to know what parts from the disco will fit your 90? Engine and wheels will go. The lift kit may or may not work, Disco weighs a lot more than the defender, but has much softer springing as standard, so you'd need to check the spring rates out before you go changing them. Axles are useful, gets you disk brakes on the rear and front could be a spare. Steering box might be useful as a spare or upgrade if your 90 doesnt have PAS. Transmission wont fit, but the transfer box could be fitted to improve fuel economy and lower RPM's in gear for quieter motorway driving. Front prop might be the same length as a spare. Quote Link to comment Share on other sites More sharing options...
defender dinky Posted June 19, 2009 Author Share Posted June 19, 2009 Your wanting to know what parts from the disco will fit your 90?Engine and wheels will go. The lift kit may or may not work, Disco weighs a lot more than the defender, but has much softer springing as standard, so you'd need to check the spring rates out before you go changing them. Axles are useful, gets you disk brakes on the rear and front could be a spare. Steering box might be useful as a spare or upgrade if your 90 doesnt have PAS. Transmission wont fit, but the transfer box could be fitted to improve fuel economy and lower RPM's in gear for quieter motorway driving. Front prop might be the same length as a spare. thanks for your reply and advice defender dinky Quote Link to comment Share on other sites More sharing options...
