blz6662 Posted June 25, 2009 Share Posted June 25, 2009 Hi Guys Not done this task before. Its scheduled time to change the filter/o-rings in the ZF 4 speed auto box and I just want to know is it possible to remove the sump pan without removing the curved tubular type crossmember? It's a straight box section one on my rangie and deffo not do-able. Also is there any other pitfalls awaiting me that I should know about - refilling etc. Many thanks in advance Baden Quote Link to comment Share on other sites More sharing options...
mickeyw Posted June 25, 2009 Share Posted June 25, 2009 The curved tubular cross member will definitely need to come out. Just undo the 8 bolts, and if necessary spread the chassis rails a little. I now use a 4t port-a-power ram for this, but before that it was a small bottle jack and a lump of timber. Make sure you're not beneath it when the whole lot drops out. It WILL hurt Quote Link to comment Share on other sites More sharing options...
