Dave M Posted June 25, 2009 Share Posted June 25, 2009 Just bought a Series IIIa , and when taking the drums off to examine brakes imagine our suprise to see them contaminated with gear oil. Stripped everything back to the axle end and no sign of any seals in the end of the axle surely there should be. Both sides the same Any thoughts/comments would be gratefully received. Dave M Quote Link to comment Share on other sites More sharing options...
Les Henson Posted June 25, 2009 Share Posted June 25, 2009 In the end of the axle tube there should be a seal - part number 217400. If the oil is inside the brake drum, then it will also be the hub oil seal - part number RTC3510 Les. Quote Link to comment Share on other sites More sharing options...
Dave M Posted June 25, 2009 Author Share Posted June 25, 2009 In the end of the axle tube there should be a seal - part number 217400.If the oil is inside the brake drum, then it will also be the hub oil seal - part number RTC3510 Les. Cheers Les...As you can see our experience at the farm with the problem disco, that you popped out to help us with hasn't put us off Quote Link to comment Share on other sites More sharing options...
Phil Hancock Posted June 29, 2009 Share Posted June 29, 2009 In the end of the axle tube there should be a seal - part number 217400. Thats only true in the front axle. Quote Link to comment Share on other sites More sharing options...
Les Henson Posted June 29, 2009 Share Posted June 29, 2009 Apologies - my mistake. Les. Quote Link to comment Share on other sites More sharing options...
