discovery 96 Posted July 12, 2009 Share Posted July 12, 2009 I have c 303s with 7:14 gears and want to know if i can change them to 5:99 ? Quote Link to comment Share on other sites More sharing options...
bishbosh Posted July 12, 2009 Share Posted July 12, 2009 Contact Jez at HOFS. He knows all there is to know about Volvo axles. Quote Link to comment Share on other sites More sharing options...
Bush65 Posted July 12, 2009 Share Posted July 12, 2009 The difference as far as gear ratio is at the crown wheel and pinion. If you find the appropriate crown wheels and pinions, you should be able to swap them to obtain 6:1 overall. AFAIK, the C306, 6x6 were ~7:1 ratio and have 4 pinion differentials (the C303, which are ~6:1 ratio, have 2 pinion diffs). I don't know what ratio was used in the C304, or how many pinions were in the diffs. So your diffs may be the stronger 4 pinion version. Also the rearmost axle housing of the C306 has less offset of the pumpkin. The portal boxes and internals are the same. Quote Link to comment Share on other sites More sharing options...
discovery 96 Posted July 13, 2009 Author Share Posted July 13, 2009 Contact Jez at HOFS.He knows all there is to know about Volvo axles. tks i already have ! Quote Link to comment Share on other sites More sharing options...
discovery 96 Posted July 13, 2009 Author Share Posted July 13, 2009 The difference as far as gear ratio is at the crown wheel and pinion. If you find the appropriate crown wheels and pinions, you should be able to swap them to obtain 6:1 overall.AFAIK, the C306, 6x6 were ~7:1 ratio and have 4 pinion differentials (the C303, which are ~6:1 ratio, have 2 pinion diffs). I don't know what ratio was used in the C304, or how many pinions were in the diffs. So your diffs may be the stronger 4 pinion version. Also the rearmost axle housing of the C306 has less offset of the pumpkin. The portal boxes and internals are the same. thank you ! Quote Link to comment Share on other sites More sharing options...
