hyperion Posted July 13, 2009 Share Posted July 13, 2009 Tried to find a posting on this problem but no luck I have a 1999 1.8 freelander. I just found out that the back door won't open. Window comes down as usual but the door itself does not get a signal to open. Tried the following. -remove the battery power and reconnecting it. This results in the backdoor window automaticaly going down. Closed the window again (hoping to reset the 0 position) but no positive result. I checked what happens. If I pull the door switch (door handle) I hear a relay switching inside the fuse compartment (CCU?), I found out that for about 0,5second the power comes on to the motor 12V/DC, but it quits and the motor is not driven. Does anyone know an other way to open the back door so I can check it? Quote Link to comment Share on other sites More sharing options...
ertin Posted July 15, 2009 Share Posted July 15, 2009 Tried to find a posting on this problem but no luck I have a 1999 1.8 freelander. I just found out that the back door won't open. Window comes down as usual but the door itself does not get a signal to open. Tried the following. -remove the battery power and reconnecting it. This results in the backdoor window automaticaly going down. Closed the window again (hoping to reset the 0 position) but no positive result. I checked what happens. If I pull the door switch (door handle) I hear a relay switching inside the fuse compartment (CCU?), I found out that for about 0,5second the power comes on to the motor 12V/DC, but it quits and the motor is not driven. Does anyone know an other way to open the back door so I can check it? Hello, I have recently removed the tailgate door trim on my 5 door TD4 to check the lock motor. There are four screws under the door pocket on the rhs of door. Although I removed mine with the door open, it should be possible to remove the screws with the door closed. There are then 8 push on clips to release. Three each side and two at the base. The trim can the be pulled back from the bottom to free the clips and lifted off a further 5 clips along the top. The lock motor is behind the membrane. Pull the rod attached to the lock motor and door latch should release the lock. Hope this helps. Eric. Quote Link to comment Share on other sites More sharing options...
