Sabre Posted July 14, 2009 Share Posted July 14, 2009 I have a tappet cover leak at the rear of the engine, driver side. Have replaced the tappet cover gasket, but no change. Breather is open & clean Did I miss a special trick in fitting the gasket ? Thanks in advance JZ Quote Link to comment Share on other sites More sharing options...
cipx2 Posted July 15, 2009 Share Posted July 15, 2009 Check if the rocker cover is not warped (both cold and warm) and gradually increase the torque on the nuts, see http://forums.lr4x4.com/index.php?showtopic=37916 Quote Link to comment Share on other sites More sharing options...
Les Henson Posted July 15, 2009 Share Posted July 15, 2009 300TDi rocker covers easily distort - I've had them leak even with a new gasket. I now use a thin bead of rtv sealant on either the old or new gasket. Save the rest of the rtv for when you get a TD5 - they do it too Les. Quote Link to comment Share on other sites More sharing options...
Sabre Posted July 15, 2009 Author Share Posted July 15, 2009 300TDi rocker covers easily distort - I've had them leak even with a new gasket. I now use a thin bead of rtv sealant on either the old or new gasket.Save the rest of the rtv for when you get a TD5 - they do it too Les. Thanks for the advice cipx2 and Les I have tried rtv sealant, no success. Will torque evenly to 25Nm when hot, and see if there is a difference Quote Link to comment Share on other sites More sharing options...
