del Posted July 20, 2009 Share Posted July 20, 2009 Hi all ive got a 1988 90 its got one of those a bars on the front with a couple of landrover spot lights on it . I wanted to strip it off and put on the standard bumper on , how do you take the bar off it seems to be bolted to the bumper and chassis , I picked up a bumper from billing on saturday and was going to fit it asap and was just wondering the right way to tackle the job, I spapped one of the bumper fixing bolts off when I tried to remove it awhile back to , i suppose you can just change them for a standard m10,any thoughts will be appreciated,del Quote Link to comment Share on other sites More sharing options...
Godlykepower Posted July 20, 2009 Share Posted July 20, 2009 The A-bar will just be bolted with 3 bolts (on either end) to the bumper, and not connected to the chassis in any way, although it will be in-line and above the chassis rails. You can access the nuts by putting your hand through the back of the bumper. If you have an A bar on a vehicle with air-con, it will probably wrap around the bumper, so is even easier to remove. Quote Link to comment Share on other sites More sharing options...
western Posted July 20, 2009 Share Posted July 20, 2009 some the existing bumper bolts to hold them on too. Quote Link to comment Share on other sites More sharing options...
del Posted July 20, 2009 Author Share Posted July 20, 2009 cheers just like to ask opinions before I tackle a job,thank all Quote Link to comment Share on other sites More sharing options...
