Reg Posted July 28, 2009 Share Posted July 28, 2009 When I bought my P38 it had a dead engine and a multipoint bodge LPG system with holes drilled into the Plenum body. RPi fitted a new 4.6 Cosworth engine in place of the 4.0 which had a cracked block in the usual place. I sourced a second hand plenum from ebay which fitted fine. Unfortunately the throttle body of the replacement came from a non cruise control donor so I lost the linkage needed to connect to the vac servo cable which lies alongside the standard throttle spindle link. RPi binned the old plenum as it was US. I don't run LPG as it is unavailable in Cyprus for road fuel. Please can someone sell me or tell me where I can get the parts to get connected. Quote Link to comment Share on other sites More sharing options...
vougese39 Posted July 29, 2009 Share Posted July 29, 2009 all you need is the bellows and the link rod which is the same as the classic as well i think there are a few on ebay will have a look in my garage as i mite have one too cheers stuart Quote Link to comment Share on other sites More sharing options...
Reg Posted August 4, 2009 Author Share Posted August 4, 2009 all you need is the bellows and the link rod which is the same as the classic as well i think there are a few on ebay will have a look in my garage as i mite have one too cheers stuart Hi, thanks for the offer, I already have the original bellows and rod assembly plus a spare, the bit Im missing is the connection on the throttle spindle as the non Cruise plemum/throttle body are different only having one attachment to the spindle for the accelerator. Thee cruise model has two attachment points in tandem but swing the spindle independently. Quote Link to comment Share on other sites More sharing options...
vougese39 Posted August 6, 2009 Share Posted August 6, 2009 best bet is from ebay then Quote Link to comment Share on other sites More sharing options...
