Ivan Posted July 29, 2009 Share Posted July 29, 2009 I am fitting a TD5 90 rear fuel tank to my 1997 Tdi 90 (fuel tank under drivers seat). At the moment the rear part of the exhaust goes under the tub at the rear. This will obviously need replacing with the later 300 Tdi exhaust which had the rear fuel tank. I have replaced the centre section with a straight through pipe so I will need at least one silencer. What parts will I need to finish this off ? TIA Ivan Quote Link to comment Share on other sites More sharing options...
white90 Posted July 29, 2009 Share Posted July 29, 2009 put a straight through silencer in the middle and the rear section with no silencer otherwise it will be to loud if driven all the time (annoying rather than thunderous loud) I used the original back box to make the pipe work req minus the silencer Quote Link to comment Share on other sites More sharing options...
barmiebrumie Posted August 7, 2009 Share Posted August 7, 2009 I am fitting a TD5 90 rear fuel tank to my 1997 Tdi 90 (fuel tank under drivers seat). At the moment the rear part of the exhaust goes under the tub at the rear. This will obviously need replacing with the later 300 Tdi exhaust which had the rear fuel tank. I have replaced the centre section with a straight through pipe so I will need at least one silencer. What parts will I need to finish this off ?TIA Ivan Where does the TD5 one go ? (apart from the rear) as mine has a small leak & will be cahnge ing engine to tdi from petrol so could do both jobs at the same time , would have some space for twin battery's then as well John Quote Link to comment Share on other sites More sharing options...
