jetemp Posted August 2, 2009 Share Posted August 2, 2009 Im sure this will have been asked before but i cant seem to find it when searching. How do i wire a battery cut off into a td5 so that it stops the car and wont cause any electrical damage to the car. Many thanks James Quote Link to comment Share on other sites More sharing options...
errol209 Posted August 2, 2009 Share Posted August 2, 2009 How do i wire a battery cut off into a td5 so that it stops the car and wont cause any electrical damage to the car. You need a battery master switch with a seperate circuit for the alternator warning light circuit (older alternators are "machine sensed" and don't much mind being cut off dead, whereas modern systems are "battery sensed" and don't like to be parted. All you ever wanted to know about alternator wiring: look near the bottom. for parts, Google FIA battery master switch - about £20. Quote Link to comment Share on other sites More sharing options...
mmgemini Posted August 2, 2009 Share Posted August 2, 2009 Exactly as in the diagranm supplied with the FIA battery master switch. Wiring diagram on here somewhere. mike Quote Link to comment Share on other sites More sharing options...
