geoffbeaumont Posted August 7, 2009 Share Posted August 7, 2009 My P38 only has base model speakers (low range front and back, tweeters in the front - no mid range, sub or power amps), and being the tart I am I've been eyeing up some of the high line options Does anyone know the part number for the mid-range door speakers? How are the power amps and additional speakers wired up? Do cars fitted with these from the factory have a different loom like on older Land Rovers (mine has no connectors for them), or do you just plug the bass speaker connector into the sub and then go from the sub to all three (two in the back) speakers? Is the sub wiring there as standard on base models or would I have to add the whole run in? Are the connections the same for the later Harmon Kardon audio systems or should I stick to components from the earlier cars? Quote Link to comment Share on other sites More sharing options...
