Snagger Posted August 7, 2009 Share Posted August 7, 2009 I have an LT 230 inmy garage. How can I tell what ratio it is without dismantling it, please? I think it has been rebuilt, so serial numbers may not be applicable. Can I determine the ratio removing nothing more than the rear or bottom plate? Quote Link to comment Share on other sites More sharing options...
errol209 Posted August 7, 2009 Share Posted August 7, 2009 I have an LT 230 inmy garage. How can I tell what ratio it is without dismantling it, please? I think it has been rebuilt, so serial numbers may not be applicable. Can I determine the ratio removing nothing more than the rear or bottom plate? There may be a sticker on the back (handbrake) face. Otherwise you could count the teeth, or turn the input shaft and count the output side revolutions You'll need to get clear marks onto greasy bits either way. Quote Link to comment Share on other sites More sharing options...
