ajh Posted August 12, 2009 Share Posted August 12, 2009 I am in the process of modifying a Series IIA dash shell to form the base for a custom dash setup for my 1992 110 CSW and I have 2007 doors on the way. Could someone with a 2007 or newer take a measurement of the full width of their dash for me? Basically the IIA dash assumed IIA doors which did not have the thick door-liner panels on them so they are slightly wider than those in the late-model Defenders and I need to cut a small amount out of the centre to get everything to fit properly. (I am asking because I am located in Ottawa, Canada and there is no way to get a 2007 to measure here). Thanks! Quote Link to comment Share on other sites More sharing options...
ajh Posted August 12, 2009 Author Share Posted August 12, 2009 Nobody? One of you must have the new type of doors. I basically just need to know how much to trim out of the centre of the dash shell so it will fit, I also need to finish restoring it and get it to galv asap. Quote Link to comment Share on other sites More sharing options...
Happyoldgit Posted August 12, 2009 Share Posted August 12, 2009 I have a Puma. You you want the full width measurement of the plastic bit of the dash is that correct? If so from what part to what bit ie edge to edge but where exactly? Quote Link to comment Share on other sites More sharing options...
ajh Posted August 12, 2009 Author Share Posted August 12, 2009 Basically I need to make sure the doors will close without hitting. Quote Link to comment Share on other sites More sharing options...
nobby3579 Posted August 12, 2009 Share Posted August 12, 2009 I've just measured my 2007 puma dashboard. I make it 139.5 cm wide from the point on the dash closest to one door to the opposite side of the dash closest to the other door. Quote Link to comment Share on other sites More sharing options...
ajh Posted August 13, 2009 Author Share Posted August 13, 2009 Ok got a bit more time. Basically I need two measures ideally. The first from door card to door card where they get closest to the dash corners and the width of the dash from edge to edge at the same point. I should be able to mark up a photo tomorrow to show exactly. Quote Link to comment Share on other sites More sharing options...
