q-rover Posted August 16, 2009 Share Posted August 16, 2009 In a 2004 MY. I assume this would be a THOR/ Bosch engine, Are they suscepteble to the problem of using coolant? Quote Link to comment Share on other sites More sharing options...
BogMonster Posted August 16, 2009 Share Posted August 16, 2009 Depends what you mean by "using"? I have had two problems with mine losing coolant - firstly one of the front cover gaskets had a weep, and now the radiator seeps a small amount around the end tanks which is a common problem. Usually drops the header tank by about one to two inches and then stabilises and doesn't drop any more. I have a new radiator waiting to go in, when I can be bothered. Quote Link to comment Share on other sites More sharing options...
q-rover Posted August 17, 2009 Author Share Posted August 17, 2009 As in the block leaking= new engine. Quote Link to comment Share on other sites More sharing options...
BogMonster Posted August 17, 2009 Share Posted August 17, 2009 Ah OK - I think they all are in theory, though have not had the problem myself (touch wood) Quote Link to comment Share on other sites More sharing options...
