dooroy Posted August 17, 2009 Share Posted August 17, 2009 I have a 2001 Td5 and as the sunroofs leaked a bit from time to time I finally decided to remove the headlining and sort them out properly . I expected to see some evidence of leaks as water dripped off the rear sunroof handle on a few occasions and sometimes when the front seatbelts were drawn out they gave a soaking to the wearer . However when I removed the headlining there was no trace of rust whatsoever - and to me both sunroofs appeared almost new . I have the Disco 2 years and it was a company vehicle and very well maintained in every way . The new appearance of the sunroofs would suggest they were replaced - and if they are relatively new where is the leak ? Would anyone with a Disco of this age have removed headlining ? and if they did was there at least some traces of rust or water ingress ? I still intend to remove them as the problem could be the seal between sunroof frame and vehicle roof . The boxes in the corners etc are perfect - sealer in place , not a speck of rust . Quote Link to comment Share on other sites More sharing options...
nicks90 Posted August 17, 2009 Share Posted August 17, 2009 yep - mines a 2000 plate D2 and when i removed the headlining there was not a spec of rust or damp, mould, general grebbiness. but the thing leaked like a sieve! Well until i fixed it..... dont believe the 'appearance' of the sealant around the plastic drain cups. Might look all nice and secure with big blobs of black sealant - ours did too until i poured water directly into the sunroof channels and watched it GUSH out from around the sealant. Quote Link to comment Share on other sites More sharing options...
dooroy Posted August 17, 2009 Author Share Posted August 17, 2009 Thanks nicks90 - every thing looked so good I thought the problem might be elsewhere . As you say the sealant etc looks perfect . Will take them out and give them an overhaul . Quote Link to comment Share on other sites More sharing options...
