angusb Posted August 27, 2009 Share Posted August 27, 2009 I have almost finished the replacement of the rotten bulkhead on my 1988 110 td but have been caught out by the indicators not working now I have the new bulkhead in. I left the wings on to make it easier to align the new bulkhead which seems to have worked ok but I cut the loom to the front light clusters on both sides as the wings were staying on. Now I have reconnected the loom where I cut it and everything is working except the indicators at the front and the back. Because it is both front and back that aren't working I think it isn't a bad connection where I cut and rejoined the loom at the front that's causing it. I was careful to label the connector blocks on the steering column when I disconnected them so they are plugged in to the right blocks. How do I go about troubleshooting the indicator relay, and does anyone know which colour wires are for the indicators? Could it be a fuse that has blown? I managed to work out that the wire to the starter solenoid had broken with a bit of advice from a couple of mates and a multimeter but I don't know where to start with this. Quote Link to comment Share on other sites More sharing options...
daveturnbull Posted August 27, 2009 Share Posted August 27, 2009 Yes, quite possibly a fuse. Also, the hazard switch is often a culprit of missing indicators. If you can't hear the flasher relay clicking & no warning light on the dash I'd start at fuses / hazard switch. Quote Link to comment Share on other sites More sharing options...
errol209 Posted August 27, 2009 Share Posted August 27, 2009 Yes, quite possibly a fuse. Also, the hazard switch is often a culprit of missing indicators. If you can't hear the flasher relay clicking & no warning light on the dash I'd start at fuses / hazard switch. Good start ^^^ The indicators are green/white on the right and green/red on the left. The flasher unit wires are light green (power), light green/brown (to the column switch) and light green/purple (to the dash trailer light). Fuse 10 (indicators) and fuse 12 (hazards) would have to go for them to pack up totally. You did re-connect all the earths (black) didn't you? Quote Link to comment Share on other sites More sharing options...
angusb Posted August 27, 2009 Author Share Posted August 27, 2009 That's done it - I'd forgotten to plug the hazard switch in. Works fine now Thanks Dave Quote Link to comment Share on other sites More sharing options...
daveturnbull Posted August 27, 2009 Share Posted August 27, 2009 Quote Link to comment Share on other sites More sharing options...
angusb Posted August 28, 2009 Author Share Posted August 28, 2009 Sometimes a picture is worth a thousand words Quote Link to comment Share on other sites More sharing options...
