Iain freer Posted September 1, 2009 Share Posted September 1, 2009 As the title says, will a 2.25 diesels flywheel housing fit a 300tdi? Quote Link to comment Share on other sites More sharing options...
Daan Posted September 1, 2009 Share Posted September 1, 2009 As the title says, will a 2.25 diesels flywheel housing fit a 300tdi? Not if it is the old 3 bearing engine (green block). If it is the 5 bearing block (brown) it might fit. The difference is in the crank seal. The later TDI engines have a seal on the flywheel fitting flange, where as the early 3 bearing blocks have the seal sealing the crankjournal. I used a 2.5 TD flywheel housing to fit my 300 tdi, but any 2.5 engine flywheel housing is ok I think. daan Quote Link to comment Share on other sites More sharing options...
Iain freer Posted September 2, 2009 Author Share Posted September 2, 2009 It is a 5 Main bearing. I guess i will just have to give it a go. Quote Link to comment Share on other sites More sharing options...
Daan Posted September 2, 2009 Share Posted September 2, 2009 It is a 5 Main bearing. I guess i will just have to give it a go. Yes, let us know how you get on. Daan Quote Link to comment Share on other sites More sharing options...
tuko Posted September 2, 2009 Share Posted September 2, 2009 I installed a 300Di in my series 3 hybrid and what I did was used the 300Tdi fly wheel housing that I matched it up to the series 3 transmission bell housing. A little creative with the angle grinder, removing a stud and placing a few new ones at the bottom gave me the result I needed to couple the motor to the series 3 transmission. More information can be found in this thread: http://forums.lr4x4.com/index.php?showtopic=25431 Cheers, Todd. Quote Link to comment Share on other sites More sharing options...
dr pepper Posted September 8, 2009 Share Posted September 8, 2009 I looked at tods link and have too fitted a 300tdi to my series, and the bellhousing fits, as tod says you have to bash one of the reinforcing supports and drill a couple of holes in the series bellend, but its not hard to make it fit. Quote Link to comment Share on other sites More sharing options...
