Posted
Have a look at this -
http://www.rapitypes.com/case_study_lrw.html
The vehicle has an intake hole on each wing, same as 2.5TD/200Tdi (LH side) and 300Tdi/TD5 (RH side), the inside of the 'Wolf' intake shields these holes and forces the air drawn-in through it's grille to pass up and over an internal baffle, before entering the intake holes.
The two intakes are joined together by pipework under the bonnet, before the air filter, see below -
(click on thumbnail for full size image in new window)
Posted
Thank you, for this answer, on the other hand on the grids that I' for my Defender, I have to buy do not have the translucent plate, is this normal???? where can I find this plate.
Regards
The exploded diagram shows all of the component parts used to make a complete intake grille.
The 'translucent plate' shown is actually a piece of foam rubber, bonded to the inside back panel of the grille and designed to stop water splashes through the grille - excess water then runs off the foam rubber and exits through the drain hole (bottom right of the grille in the picture).
